Hi
I've recently moved house and am in the process of reinstalling my system.
I'm currently experiencing the following problems with the BV8-40 (master TV).
1. Analogue channels are poor quality (RF In) - I know the aerial is good as I've connected a MX4002 directly to the aerial and it tunes perfectly.
2. DVB - cannot tune any channels - when I switch the aerial input into the DVB input socket.
3. The transmitted (through signal) via the BV-8 into link rooms is poor - eg the MX4002 has far worse reception than when connected directly. NB I'm not using a RF amp so this could be the problem.
4. When used a link TV the MX4002 does not pick up any the STB (Sky+) or ATV from the BV-8. (I wasn't really expecting the AppleTV to show as I've only connected it using HDMI to the main TV.)
5. Finally(!) - there appears to be a fault with the 'Apple Remote' control software as only a few of the keys on the Beo4 produce any activity on the ATV, and even then it's the wrong action. E.g. 'Stop' works as 'Enter', Up/Dn arrows don't work at all. The AppleTv works fine with an apple remote. The PUC cable etc works fine when I switch it the Sky box.
If anyone can help with any or all (!) of the above then I'll be very grateful.
AP
