Latest post 10-05-2010 5:59 PM by Doctor. 4 replies.
Page 1 of 1 (5 items)
  • 10-05-2010 8:54 AM
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Collection of B&O amps and speakers - how to use and/or mix - What would YOU do?
    After several acquisitions (and some sales) I am ready to do the final set-up in my homeoffice.
    Available are:
    Beosystem 7000 (Beomaster, Beogram CD, Beocord, MCP 6500)
    Beomaster 4400
    Beolab 5000 (soon a Beomaster 5000 tuner will be added)
    Beovision MX4000
    Beogram 4002
    Beovox 5000 flat panel speakers (incl. wall mounts)
    Beovox CX100
    Beovox S45.2 (Stands available)
    Restrictions:
    I cannot use the speaker 1 connections for the Beomaster 7000, they are faulty. For this reason a Aux Conncection to the Beovision would require AV TV to have the TV sound on the speakers attached to the Beomaster 7000. For this reason I dropped the aux link connection.
    Set-up so far:
    - Beosystem 7000 connected to Beovox 5000 flat panel speakers (CD/Radio)
    - Beovision MX4000 with Bevox CX100 speakers attached (TV)
    - Beolab 5000 AND Beomaster 4400 (with Beogram 4002) share the same speakers (Beovox S45.2) via a Dodocus Ubox 3. Beomaster 4400 for radio/records and Beolab 5000 for PC/MP3s.
    Any recommandations on changing this setup?
    How would YOU use the availabe systems???
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 10-05-2010 10:21 AM In reply to
    Re: Collection of B&O amps and speakers - how to use and/or mix - What would YOU do?
    The problem with the BM7000 speaker 1 connection is the mute relay. It needs taking apart and cleaning or replacing. Well worth doing and a very common fault!
    Your set up is certainly different! The BM4400 is actually a better amplifier than the Beolab 5000 - it is after all 10 years younger in design and is direct coupled. However I use a Beolab 5000 as well as I just like it!
    To be honest, the only thing I would do is fix the BM7000 as it is clearly irritating you!
  • 10-05-2010 4:41 PM In reply to
    • valve1
    • Top 500 Contributor
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Doctor:
    I am surprised to hear this (having never heard or seen either of them) I had the impression that the 5000 was the bench mark by which others were judged from the posts that I have read?
  • 10-05-2010 5:33 PM In reply to
    valve1:
    Doctor:
    Nah - that is the Beomaster 8000.
  • 10-05-2010 5:59 PM In reply to
    Debatable - I like the 8000 but prefer the 4400. The 5000 is the benchmark for build quality. The progress in circuit design was accompanied by a decline in quality of materials. It is a matter of opinion as to where the ideal compromise is met. I like the late seventies (4400), some prefer the early 80s (8000). Both are reasonable choices - it just depends on your priorities. Late sixties is another choice - I have hedged my bets and got a choice!
