1st March February 2012
10-04-2010 11:05 PM
sodoi18
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.50.71/avatar.jpg)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 02-06-2010
- USA
- Posts 194
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
How to differentiate visually various powerlink cables
I know the MK3 has a triangle.
Is it possible to identify MK2 visually from Mk1 or Mk3.
Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
mediabobny
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.26.92/avatar.jpg)
![Top 200 Contributor Top 200 Contributor](/Themes/beotheme1/images/rankicons/rankTop200.gif)
- Joined on 04-19-2007
- Greenwich Village, NYC
- Posts 336
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Re: How to differentiate visually various powerlink cables
Yes, it's fully wired and visibly thicker. Here's a summary of the three types.
sodoi18
- USA
- Posts 194
Fully wired would mean 5pin or 7pin?
Is there a relationship between pins and mk2 or mk3?
beocool
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.55.29/avatar.jpg)
![Top 10 Contributor Top 10 Contributor](/Themes/beotheme1/images/rankicons/rankTop10.gif)
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
sodoi18, What a great avatar!
sodoi18
- USA
- Posts 194
Is it correct that mk2 has 8 pins
tournedos
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.61.93/avatar.jpg)
- Joined on 12-08-2007
- Finland
- Posts 5,808
They all have 8 pin connectors! However, Mk.2 is the only version that has them all connected.
Evan
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.06.67/avatar.jpg)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
beocool:
Here Beek! I snapped this for you,
beocool
- the Netherlands
- Posts 5,514
evman140:
beocool:
Thanks, Ev! That is so cool!
Keith Saunders
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.92/avatar.jpg)
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
Actually all B&O Powerlink cables have been replaced with a new type.
The new Power Link cables are double-shielded Ø5.5 mm cables.
The following additional Power link cables chnages have been introduced with the improved double-shielding and new part numbers
- 100 metre cables will be replaced by 50 m cables with Power Link plugs to use in connection with the Power Link Junction Box.
- A grey installation cable with metre marks has been introduced for 300 metre professional cable reels.
- Fully mounted Power Link cables Ø3.5 mm are replaced by extra shielded type Ø5.5 mm cable.
Page 1 of 1 (9 items)
