Latest post 10-03-2010 8:55 AM by Medogsfat. 4 replies.
Page 1 of 1 (5 items)
  • 10-02-2010 2:43 PM
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Beovox S35 X-over access.
    I suspect I already know the answer. Does the moulded plastic back come off or do I access the crossovers by removing the bass drivers?
    I've got a rather nice pair of these in teak which I've just reconditioned the cabinets of (previous owner mistook them for coffe tables) & would like to replace the cap's in the crossovers.
    For anyone interested in my method of refurbing the cabinets :-
    Sand down with 400 grit sand paper to remove the old laquer & any surface blemishes. Then apply button (French) polish in 3 coats. Lightly sand with 800 grit paper after the first coat, then with steel wool after coats 2 & 3 to give a super flat surface. Finally apply beeswax & rub.
    I'll post a finished photo tomorrow when I have decent light.
    Chris.
  • 10-03-2010 6:11 AM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beovox S35 X-over access.
    Yes, woofer out.
  • 10-03-2010 6:35 AM In reply to
    • Medogsfat
    • Posts 4,045
    Thought so.
    Cheers Martin.
    Chris.
  • 10-03-2010 8:04 AM In reply to
    Very nice finish.
  • 10-03-2010 8:55 AM In reply to
    • Medogsfat
    • Posts 4,045
    Thanks Peter, button polish is the way to go to enhance the natural beauty of the grain.
    They look even better in the flesh.
    Chris.
