Latest post 11-08-2010 2:29 PM by f5434964. 6 replies.
Page 1 of 1 (7 items)
  • 09-29-2010 3:10 PM
    adding BS5 to a BS9000
    Hello!
    I just wanted to add a Beosound 5 to an existing system of a Beosound 9000 with Beolab 8000; the BS5 is supposed to be in the same room as the BS9000 connected via masterlink
    Now my problem is that I cannot add the BS5 on my Beo5; either it says that I have to add a Video-System first or I have to add a new zone; but I don't have a TV and I don't want to add a new zone - the two systems are in the same room
    I also tried to change the audio option - without success
    Can somebody help please?!
    Regards Elmar
  • 09-30-2010 2:45 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: adding BS5 to a BS9000
    Hi Elmar, I'm not sure why it requires a TV or a new zone, however, you can create a new zone with no problems and then you can choose to hide it so that it won't appear on the screen. I also had the same issue for the beoport and I the did the above mentioned. Best regards Spiros
    Best regards
    Spiros
  • 09-30-2010 11:52 AM In reply to
    Hello Spiros!
    Thanks for you answer! As you told to do - I have to hide some buttons (from the TV) or the zone; I'm just wondering how it would be done if I ask a official dealer to do the setup...
    What would you suggest: setting BS9000 or BS5 as audio master?!
  • 10-01-2010 2:59 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hello Elmas, You can hide the zone comletely. Most probably your dealer would do the same but I cannot tell for sure. I think that the BS9000 should be the master as long as it is N.Music ready and BS5 in Option 0 if they are on the same room. Give it a try and update us. Best regards Spiros
    Best regards
    Spiros
  • 10-11-2010 10:51 AM In reply to
    HI Elmar,
    do you solve yr prob in the meantime or not ??
    i have this combination several month working very fine....
    any further questions, just write a PM with a tel number....
    Cheers from germany,
    M.
  • 10-18-2010 12:37 PM In reply to
    Hello!
    I'm still waiting for my BS5 so I haven't change my config yet....
    Thanks for your offer!
    regards elmar
  • 11-08-2010 2:29 PM In reply to
    Hello!
    I got my BS5/BM5 last week and did the setup on Saturday; I linked the BM5 to my existing BS9000 (ML); on the Beo5 I've added to BS5 as a new zone; everything works fine; the BS9000 is the Audiomaster - at the BS5 I said "audiomaster no"; there are only some issues:
    * after listening to n.music and switching to eg radio the BS5 is not turned off
    * the BS9000 does not switch to n.music if I start the system with the BS5
    * I've copied a playlist from ITunes to the BM5 with Beoconnect (drag and drop on the green button); unfortunately the system copied the tracks - not a list! So I have all the tracks from the list twice! Is there a chance to get rid off those files? Do I have to erase all of them on after another? And how do I get a LIST?
    Greetings Elmar
