I am wanting to purchase a Beovision 10, but would like it to match our Beolab 1s. Dealer has confirmed I could purchase a replacement speaker cover for a Beovison 5 in the color of our speakers. My idea is to remove the fabric from the 5's speaker cover and use it to recover the speaker cover for the 10. As the 5 was a 42 inch and the 10 is 40 inch it should be large enough.
Questions are, what are the exact dimensions of the speaker cover on a Beovision 5?
And, can the cloth be removed? Is it attached just around the edges or are any portions of the fabric in the middle, visible areas, glued down?
Thanks!
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
