I recently acquired a BeoMaster8000/BeoGram8000/BeoCord8002/M150 setup which is in great cosmetic condition, but obviously needs some sorting.
The first issues that presented itself was the standard tachodisc spectacle on the BeoGram. Dillen sorted me with a replacement and I bought the cap. kit while I was at it.
After some weeks of procrastination I have swapped the tachodisk, which solved one problem, but made it painfully obvious that I had to take care of the one next in line. Mainly the arm refusing to lower onto the vinyl, a rather annoying flaw when it comes to a turntable.
The arm stops at the exact same position, regardless of the size of record on the platter.
I have attempted the <</play workaround that some have posted in similar threads, but to no avail. And yes, this unfortunate behaviour also occurs with a stylus present.
As Dillen has pointed out to me I probably should've replaced the caps at this point, but since my soldering skills leaves a lot to be desired, I thought I'd check if there are anything else I should do while I practice soldering on equipment of a more mundane nature.
To the best of my knowledge the BeoCord 8002 worked like a charm at first, it at least played tapes without any fuss, but yesterday it merely produced a loud clonking/clicking sound and that was about it. Does this mean that the belt has finally given up, or are there a vast number of possible explanations for such behaviour ?
Also, the display performs a minor voodoo ritual as I press play, sadly I didn't take a picture of this to include here.
Finally, I apologize for the fact that my first post here is a bunch of questions that you've all probably grown tired of ages ago.
Robert
