Latest post 09-26-2010 8:52 AM by stefan. 2 replies.
Page 1 of 1 (3 items)
  • 09-26-2010 6:16 AM
    • marke
    • Not Ranked
    • Joined on 09-26-2010
    • Posts 1
    Controlling Philips LED TV with Beo4
    Hello!
    I'd like to control my Philips TV and IPTV reciever (Amino) with Beo4. What would be the solution? Searched and found Lintronic and IRTrans but is there any other solution and which is the best/simpler?
    Thanks in advance!
  • 09-26-2010 7:10 AM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Re: Controlling Philips LED TV with Beo4
    Hi
    I have the Lintronic and have had it for a couple of weeks now.
    It is very easy to use and setup i would 100% go for that.
    If it does not have the IR codes it can learn them.
    The hardest part is deciding what buttons you want to do what.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 09-26-2010 8:52 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Welcome to Beoworld. I agree. Go for Lintronic. You can program macros to start up your TV and your receiver just by pressing TV - just an example.
    Stefan
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
