Latest post 09-26-2010 1:12 AM by Beophile. 0 replies.
Page 1 of 1 (1 items)
  • 09-26-2010 1:12 AM
    • Beophile
    • Not Ranked
    • Joined on 04-18-2007
    • Washington, DC
    • Posts 42
    Need help with odd Master Link problem...
    Hello all,
    I'm having an odd problem with ML in my system and I am wondering if anyone has encountered a similar problem.  My system consists of three rooms.
    Room 1: US Beosytem 1 (set to option 2) and Beosound 9000 (set to option 0)
    Room 2: US Beosystem 1 (set to option 6 (I could be wrong about this one)) and Beomedia 1
    Room 3: Beolink Passive (set to option 6)
    All of the above equipment is connected via preterminated ML cables and an ML distribution box.  I had the system setup and working for several years. However, this past spring my Beomedia 1 stopped working so I sent it in for repair.  I finally got around to hooking the Beomedia 1 back up and noticed that my Beolink Passive stops working (becomes completely non responsive) whenever I connect the Beomedia 1 to its ML cable.  I thought the Beomedia 1 had an ML fault and was crashing the ML network, but this does not appear to be the case.  The Beomedia 1 is functioning with both of the US Beosystem 1s regardless of whether the Beolink Passive is connected via ML or not. Also, the Beolink Passive becomes response again as soon as I unplug the ML cable from the Beomeda 1.  I'm at a loss.  Any thoughts?
    Beophile
