Latest post 12-21-2010 11:22 PM by Evan. 114 replies.
Page 5 of 5 (115 items) < Previous 1 2 3 4 5
  • 11-25-2010 1:24 PM In reply to
    Re: Beoworld iPhone Application
    Hey, everyone with an iPhone or iPad, the new version of the Beoworld App is now on the App store. It fixes the & bug and is now compatible with the iPad.
    Check my App page to download it.
    p.
  • 11-25-2010 1:43 PM In reply to
    Hi Phil!
    Thanks, I have already downloaded it.
    I hope it will not cut the postings any more. This posting will test it...
    Regards
    Räuber
  • 11-25-2010 1:47 PM In reply to
    It used to cut posts that contained the & sign, which is commonly used on this site...
  • 11-25-2010 2:55 PM In reply to
    • msinn
    • Not Ranked
    • Joined on 12-11-2007
    • Germany
    • Posts 48
    • Gold Member
    Phil,
    Why do you say it is NOT compatible with the iPad? It works briliantly!
  • 11-25-2010 2:58 PM In reply to
    I meant "now", not "not", I have updated the post!
  • 11-25-2010 3:00 PM In reply to
    IPad update is great! Thanks for the work on the app.
    Cheers,
    Frank
  • 11-28-2010 3:09 AM In reply to
    Thanks for this App that I use very regularly.
    One thing that I miss is a search possibility. Would be great to be able to search through the forum.
    Probably this can be added in one of the next releases.
    Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 11-28-2010 3:30 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    May I also add another issue?
    If I reply for the first time in a thread from the App I don't get the Enable email notification which I find very useful.
    Could that be also intergraded as well in a future update ?
    Best regards
    Spiros
  • 11-28-2010 1:07 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Spiros:
    WOW!!!!! That was very fast. I posted a new topic and it appears that it does work! BRAVO Philippe!!
    Best regards
    Spiros
  • 11-30-2010 5:11 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Hello just some info I was monitoring the months prize draw on the app and I could only get up to two pages via the iPad
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 12-01-2010 3:34 AM In reply to
    The App gets the max number of page when you enter a thread. It displays the most recent post at the top.
    You need to go back one level and in again to see newer posts.
    You need to scroll down, to see older posts.
    P.
  • 12-01-2010 4:33 AM In reply to
    • StUrrock
    • Top 500 Contributor
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    PhilLondon
    Nice work, send me a pm I have a present for you!
    regards
  • 12-21-2010 2:06 PM In reply to
    Two more things I would like from this app (which is my favourite app on iPod touch) already:
    • Date when a post was done
    • See pictures completely. Bigger pictres are cut right now and cannot be scrolled.
    But again: great app Philippe!
    Heribert
  • 12-21-2010 2:14 PM In reply to
    Thanks for the feedback.
    There has been a news that Beoworld will be upgraded to a new version soon.
    This is very likely to break the Beoworld App, and I will probable have to re-write a big part of it to get it to work with the new system.
    I won't be touching the App until this upgrade happens, but will try and take into account the feedback at that point.
    P.
  • 12-21-2010 11:22 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Yes, well done! I just got my first iPod touch and this was the first app I downloaded!!!
    Using it right now as a matter of fact!
    Evan
