Latest post 09-27-2010 4:13 PM by Jan Lynge Jakobsen. 4 replies.
Page 1 of 1 (5 items)
  • 09-22-2010 3:02 PM
    No clock on Beolab 3500
    Hi
    I recently had to completely reinstall my MacMini. I have Linkplayer and a Beoport. The Macmini acts as mediacenter in the living room - no other B&O devices attached except for the Beoport.
    In the kitchen I have a Beolab 3500.
    The setup works perfectly (thx to Linplayer :-)), but one thing wonders me - since I reinstalled, the clock no longer shows in the Beolab 3500 Confused
    The Beoport is set to Option 0 and as I mentioned playing music, netradio etc. works without any problem.
    I have tried to reset the Beoport, the Macmini and the Beolab speakers and turning them on in different orders, but nothing has brought back my clock :-)
    Any suggestions?
    Best regards
    Jan
    By the way - SnowLeopard 10.6.4 and the latest version of Linkplayer installed and ...it used to work!
  • 09-23-2010 10:22 PM In reply to
    Re: No clock on Beolab 3500
    Is it still a problem?  I find it sometimes takes awhile.  Like hours even.
  • 09-26-2010 8:48 AM In reply to
    Hi
    Sorry for the late response - have been away for a couple of days.
    Unfortunately it's still not working and it has been on for 5 days now... :-)
    The last time it worked, it only took a few minutes.
    Best regards.
    Jan
  • 09-27-2010 3:40 PM In reply to
    LinkPlayer does not send (and has never sent) the clock signal on the masterlink.
    I suppose you had an audiomaster before, or a TV on the masterlink.
    Try to reconnect it for a while, this should set the clock on the Beolab.
    P.
  • 09-27-2010 4:13 PM In reply to
    Hi Phil
    Thx for the answer. No I never had an audiomaster attached to it. The only thing I can think of, is that i briefly had a windows computer (with the B&O SW) attached to the Beoport. I suppose that might have been it?
    If so - sorry for the confusion. Any chance Linkplayer can/will send the information in a future release? :-)
    Best regards
    Jan
