Latest post 09-23-2010 10:05 AM by Chrisreunion. 6 replies.
Page 1 of 1 (7 items)
  • 09-21-2010 2:17 PM
    • madskp
    • Top 500 Contributor
    • Joined on 11-06-2007
    • Denmark
    • Posts 111
    • Gold Member
    Differences between Beolab 4 & Beolab 4 PC
    Can somebody tell me the difference between the Beolab 4 and the Beolab 4 PC. I can't seem to find anything about it other than the Beolab 4 has a switch for a dedicated PC mode. But there seems to be a price difference anyway.
    Thanks in advance
  • 09-21-2010 2:24 PM In reply to
    • mhw
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    Re: Differences between Beolab 4 & Beolab 4 PC
    As far as I know, the PC version only have minijack input, no powerlink...
    PC version has no powerlink socket, and hence is quite a chunk cheaper.
  • 09-21-2010 3:10 PM In reply to
    The Beolab 4 has also Roomadaptation. If you want to use the speaker for your audio-setup i would recommend the Beolab 4 for this.
    It makes a hugh change, and is the reason i would buy de Beolab 4.
  • 09-21-2010 5:16 PM In reply to
    I had the PC version in the past. I just got some Powerlink -> Mini Jack cables custom made to the length I needed and they worked perfectly through my Overture. I don't see why you'd spend extra on the normal version....
    My B&O: 2009 Catalogue and Pricelist
  • 09-22-2010 11:37 AM In reply to
    • madskp
    • Denmark
    • Posts 111
    • Gold Member
    Thank you for the answers. Now I'm not as confused as before.
    If I am going to buy the they are going to be the back speakers in a sorround setup. Not sure what I will use for front speakers yet.
  • 09-23-2010 10:05 AM In reply to
    I also bought a pair of BeoLab 4 PC instead of the Powerlink version, because they are easier to connect to any non B&O product, and also because of the lower price.
    I used them as rears with Powerlink adapters and they performed well (in 5.1 setup).
    Now they are at the office as proper PC speakers and everybody wants a pair! Big Smile
    Reunion Island is greeting you!
