Latest post 09-27-2010 3:57 PM by Keith Saunders. 6 replies.
Page 1 of 1 (7 items)
  • 09-21-2010 12:44 PM
    Configuration lost
    Hello....
    I am writing this message hoping someone can help me, because it seems a disaster has happened to me.....
    I have had a Pc crash and many data were lost. My Beo5 configuration folder, has broken and it was possible to get back only few frammentary parts of file......
    I have bought a new hard disk and now i have an 'empty' Pc.
    Is it possible to 'download' from Beo5 to Pc the installed configuration?..... I worked hard about this from many months! I was able to control everything in my house from my Beo5, so, now it is very very hard to begin from zero again.....
  • 09-23-2010 8:41 AM In reply to
    Re: Configuration lost
    Nobody knows a way to help me?....
    Where is the configuration stored in Beo5? Is there a way to 'extract' it?
  • 09-23-2010 9:55 AM In reply to
    I'm sad to say that there is no way to extract the code from a Beo5 and turn it into code for the Configuration Tool. The code downloaded into the Beo5 is serialized, as you must have seen several times, before you lost your configuration.
    This process is not reversible.
    There is a proverb which says: Real men do not backup - they cry!
  • 09-23-2010 11:15 AM In reply to
    ..........i suspected.....
    I have some parts of the configuration filer i have got back after Pc crash.
    In 'Beo5 configuration tool' folder, where can i find the configuration files to store into Beo5?
    When the software start, it loads something about the configuration....... what?
  • 09-24-2010 3:26 PM In reply to
    As stated your configuration is not reversible from your Beo5
    The configuration is held in a configuration file called "Configuration.xml" and is located in directory:-
    C:\Bang & Olufsen\Beo5 Configuration Tool\Clients\SERIALNUMBER\Configuration.xml
    Where SERIALNUMBER is the serial number of your Beo5 and is 8 digits long.
    Regards Keith....
  • 09-27-2010 3:32 PM In reply to
    THANK YOU!!!!!!!!!!
    I have found it with a helpful software.....
    It was still able to be read, and so i have back the file!
    My job is not lost!
    Thank you Keith!!
  • 09-27-2010 3:57 PM In reply to
    I am very pleased that you managed to recover your configuration... Smile
    Regards Keith....
