Hello friends,
I have a BG 4004 that change the speed himself, but no from 33 to 45, when it arrive at the middle of the disc the speed go down and after the 3/4 of disc turn up. What I can check ? Thank you
As knowone else has asked yet I will have a go...
Not sure if this makes sense.. is this when the arm is moving to engage a 7" 45 record that you get this problem?
Olly.
Hello, no, I use only 33 record and around the middle the speed go down and after some turns came back normally. I check the arm and it seems good.
If I go with << to clean the disk , the speed not change.
Something catching between platter and transport?
Check all the capacitors on the Control PCB for high ESR.
Most will need replacing.
Menahem
Learn from the mistakes of others - you'll not live long enough to make them all yourself!
Step1: Something catching between platter and transport?
Hi, it no catch.
I will try to check the capacitors. Thank you
