I totally understand the 50hrz and down thing, but my dealer was saying that it actually cuts off lower frequencies abruptly. I used a RtA and can see that the player is indeed pushing freqs below 60hrz. One issue I discovered is that my harmon avr-247, which Im basicly using as a pre-amp, has a setting for large speakers, the issue is that the crossover cannot be disabled and the lowest I can set it is at 40hrz, I know that it does not block at exactly 40hrz and down, but that it signifigantly cuts the freqs off or tappers them down. I should be able to totally turn off this feature, as my vandys can go down to 26hrz. the 10in woofer is designed to handle sub 40hrz and down. Harmon assumes that you are going to use a sub to handle LFE. in my case Im running 2ch stereo and dont have my sub hooked up. So I guess Ill look into a true pre setup that can also do home theater 7.1 decoding like the emotiva pre. Im not too happy but I doubt that harmon will push a firware update just for me. Im very sad.
Thanks for all the advice. I think i am going to order the soundsmith and sell my mmc4 on ebay or here as I wont be needing it. Overall I love the player, but plan on putting a new belt on in the near future as well as using some oil to service it.
You guess are great.
