Latest post 09-18-2010 4:57 AM by IngvarW. 1 replies.
Page 1 of 1 (2 items)
  • 09-14-2010 3:45 PM
    DVB-HD Update guide?
    Hello. Does anyone have the update guide when you are going to update the DVB-HD with the downloaded software from B&O. By some reason I cant download the guide on how to install the update. There seems to be some problem on the B&O site for that.
    Brgds Ingvar
    Collector since 1996, BS5/BM5, BL3*4, BL11, BEO6, BV10-46, BL2000, MX4002, Beocom6000, Beotalk1200
  • 09-18-2010 4:57 AM In reply to
    Re: DVB-HD Update guide?
    Well, now B&O have fixed the site so you can download the update guide again. Thanks, Ingvar
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
