Latest post 09-14-2010 2:20 PM by Jesacco. 2 replies.
Page 1 of 1 (3 items)
  • 09-14-2010 1:42 PM
    Beocenter 9000 intermittant channel
    Hi, I am new to the forum, and just purchased my first B&O piece to add to my collection, and I must say, it is a fine piece of electrical artistry. It all functions almost perfect, but one of the speaker channels do not work until I spike the volume up until it comes on. From that point on, it works great until I turn the sound off, or shift between inputs. I have worked a lot with electronics, so I can find my way around the boards, I just can't figure out what may be causing this problem. If anyone has any input, it would be greatly appreciated! Thank you ahead of time!
  • 09-14-2010 1:49 PM In reply to
    Re: Beocenter 9000 intermittant channel
    Hi Jesacco,
    It sounds to me like the mute relay, if it doesnt happen on the speaker '2' sockets it probably is .
    enjoy your new system
    jason
  • 09-14-2010 2:20 PM In reply to
    That was exactly it! I can tap on the relay at it engages. Thanks so muich for your help!
