Hi Guys
Looking for some information on how to convert ir codes to hex code, the reason being I'm about purchase the redeye remote, this is a small device, that plugs into the headphone socket and allows it to convert the audio signal to ir, the only problem is there are know bang & olufsen codes, what i need is the hex code, if anybody can help it would be appreciated
