I don't think it is worth it. You may decide to upgrade it much later in the future though, as there is likely to be a much bigger leap in performance. Liken it to upgrading your computer every time there is a slight increase, just not worth it.
As soundproof says, the money would be much better spent on improving other things. Maybe if you're interested, improving the acoustics of the room?
