Latest post 06-28-2007 1:17 PM by mhs. 3 replies.
Page 1 of 1 (4 items)
  • 06-28-2007 12:38 PM
    • mhs
    • Not Ranked
    • Joined on 05-14-2007
    • Posts 2
    Need help connecting iPod to Avant
    How do I connect iPod to my Avant in the best way? I have a cabel with white, red and yellow connections, but i cant get any sound.
    Do I also have to do someting to my Beo4?
    Morten
  • 06-28-2007 1:03 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Need help connecting iPod to Avant
    Connect your iPod to the connections hidden behind the little plastic cover found in the top right, just below the controls. Just pull the plastic cover off.
    Press LIST and cycle through until you see CAMERA on the display. Press GO and tada! It works Smile (hopefully)
    If your Beo4 never shows CAMERA, then press STANDBY and LIST at the same time, and cycle through until you see ADD?. Press GO and cycle through until you find the function you want to add, in this case CAMERA, and press GO.
     Weekly top artists:
  • 06-28-2007 1:08 PM In reply to
    • Kiwi
    • Not Ranked
    • Posts 45
    On the back of the display panel (on the top right of the avant) you'll find a white, red and yellow connector (as wel as S-Video and phones). It's possible that you need to remove a small plastic cover in order to get access to these connectors.
    On the Beo4 press (a couple of times LIST in order to get) CAMCORD.
    This should work.
     Kurt.
  • 06-28-2007 1:17 PM In reply to
    • mhs
    • Not Ranked
    • Posts 2
    Thanks Alex,
    It worked great!
