Latest post 09-12-2010 7:46 AM by 9 LEE. 6 replies.
Page 1 of 1 (7 items)
  • 09-12-2010 6:01 AM
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    iTunes Dead - Help!
    Hi All !
    Well, i had the little box flash up at me notifiying me of the latest Mac software updates, so i clicked 'install' and waited for it to do its thing.  Of the updates was the latest iTunes update along with three or four others, so i restarted the computer and clicked to open iTunes to see what they had done with it..
    However, to my horror - iTunes wouldn't open Surprise
    I get the following message...
  • 09-12-2010 6:04 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Re: iTunes Dead - Help!
    So, i click 'relaunch' a few times and the following appears..
  • 09-12-2010 6:07 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    I then click 'Reset and relaunch' but to no avail...  the cycle starts again.
    I've (to my knowledge) totally de-installed BeoPlayer and Beoconnect (i have a BeoSound 5) - but still no luck..
    How can i check i've totally de-installed BeoPlayer, and does anyone have any suggestions?
    Lee
    Smile
  • 09-12-2010 6:25 AM In reply to
    Go in the Itunes library & remove the plugin - there was a thread on this before.
  • 09-12-2010 7:12 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    It won't let me open iTunes to get to the library! Super Angry
    How do i open iTunes to get to the library and remove the plugin?!
    I'll search for the thread  - sorry, i never saw that one..
    (edit - just read the thread and i'm still stumped..)
    Lee
  • 09-12-2010 7:23 AM In reply to
    You don't need to open iTunes - use the finder. Go to your name - mine is just below Desktop, then library, itunes,itunes plug ins and you should find it there. Put it in the trash and delete it.
  • 09-12-2010 7:46 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    After a phone call from Peter, i've got iTunes open!  Thank you Peter Smile
    I'm going to try and re-install Beoplayer and see what happens.  I'll keep you informed.
    Lee
    Smile
