Latest post 09-12-2010 4:13 PM by Pauliander. 10 replies.
Page 1 of 1 (11 items)
  • 09-09-2010 1:06 PM
    Projector Recommendation
    Hi Beoworlders,
    I am thinking about adding a projector and an electrical screen to my set-up (bv 10+beo5+bl3+samsung br+appleTV).
    Any projector recommendation/advice?
    Thank you
  • 09-09-2010 1:40 PM In reply to
    Re: Projector Recommendation
    I have a Jvc DLA-HD 1,A great projector! Have a look at the new models that they have,all have great reviews.
    I used mine on a Bv7-40 mk 3 now have 7-55.
    You can now get some projectors that do 3D if your after that! Projection is a good way for 3D,as nice big screen sizes,so would get the effect unlike from a tv.
    Look around,as you can get projector/screen deals.
    Hope this helps.
    Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
  • 09-09-2010 1:47 PM In reply to
    Bv7Mk3:
    Hope this helps.
    If i may ask, do you use an HDMI cable to connect BV7 to the projector? Because i think the projector out of BV7 is VGA. Could you please clarify because i am interested on the issue.
    -Dimitris
  • 09-09-2010 2:16 PM In reply to
    DrDimitris....On the Bv-7-40 Mk3 which is full 1080p, I used the Projector Dvi out socket but needed to attach a Hdmi to Dvi adaptor to use my 15m Hdmi cable. You could always use a Hdmi to Dvi lead (Hdmi on one end Dvi on the other to the tv) If you have a 7-40 with a Dvi socket but I wanted to use my Qed cable so used the converter plug.
    My bedroom Bv7-32 has a Vga port not a Dvi fitted.
    The Bv7-40 Mk3 and the Bv7-55 both have a Dvi connection.
    The Bv7-40 tv's from the Mk3 onwards is a full 1080p tv.
    Hope this helps.
  • 09-09-2010 3:58 PM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Hi there
    I have the optoma HD65 720p projector and the optoma panoview 96" electric screen.
    It is amazing, i will one day change to the 1080p version / or the 3d if the bs3 supports it
    good luck i love watching film on the beemer
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 09-09-2010 4:19 PM In reply to
    I have a Sim 2 connected to a BeoSystem 3 in the living room and a Runco connected to the Avant in the bedroom for enjoying movies while in the jacuzzi with champagne and company. Ideal for date nights.
  • 09-09-2010 5:28 PM In reply to
    Bv7Mk3:
    Hope this helps.
    I am familiar on this and thank you for the answer. What i ask is i thought you switch to prozector by pressing FORMAT, 0 on BEO4 to activate the projector port. With your setup is different i think. How do you switch to projector mode?
    -Dimitris
  • 09-09-2010 7:36 PM In reply to
    Yes It is FORMAT...0  on the BEO4 to switch to the projector mode on the Bv7-40 Mk3 and the Bv 7-55.
  • 09-10-2010 3:09 AM In reply to
    Bv7Mk3:
    Thank you. I thought FORMAT...0 could only activate the VGA port.  Now let'w continue with reccomendations on Beofab's question. I am also curious on what other projectors Beoworlders use.
    -Dimitris
  • 09-11-2010 3:45 AM In reply to
    We use a Barco 1208/2 , resolution 1600x1200p which is incredible
    they are large though and weigh more than 80kgs so youll need a can of redbull before you can lift it above your head to ceiling mount it
    If you can ever find one (and beat me to it) the Barco 909 is the top of the line with a max resolution of 3200x2560p
    9 inch crt tubes with around 20,000 hour tube life
    all easily run hd via a HDFURY 3
    jason
  • 09-12-2010 4:13 PM In reply to
    Hi Beofab, I have the Epson EH-TW5500 and I'm very satisfied with it (great value for money).
    You may want to check: http://www.projectorreviews.com/ to learn more on different types and options.
    Concerning the size of the screen I have chosen for a 106 inch screen (in a 50 m² living room).
    If you have the space don't go for a small screen - IMHO it's simply size which makes the difference and no television comes even close.
    BC2 DAB, Lab 1, Lab Penta, beo4, beocord 1101.
