Hi to all, does anybody know how i can run the Test Mode of a Beosound 9000 MKI via the Beo4. I am Silver Member, but i just found the Manual for MKIII.
The "trick" mentioned in the forums of using SHIFT 9-0-2-5-8 does not function.
I am keen to be able to do this as at the moment i have a cd mechanism that moves to the discs , clicks a few times and then goes to pause before switching off (CD does not spin)
Thank you for helping
Phil
