Latest post 09-09-2010 6:58 PM by Churchyardd. 2 replies.
Page 1 of 1 (3 items)
  • 09-08-2010 3:01 PM
    • Churchyardd
    • Not Ranked
    • Joined on 03-25-2010
    • Deventer, Netherlands
    • Posts 31
    Beo4 does not respond to keys
    Hi all,
    Maybe somebody can help me out with this: My beo4 responds very poor to the keys suddenly
    The display is fine and I can switch to V-tape and A-tape and some more (althought the TV does not react). But then I cannot switch to TV back anymore; the display does not react and neither the TV.
    Or, to put it in another way: the TV does not react to any key at all, but the remote's display reacts to some keys. I stripped the thing to PCB board level and removed the keypad, cleaned it and so on, but to no avail. It is clear that when I press the buttons directly with my fingernails, the reaction is the same; so either the keypad (i mean the soft see-through thing underneath the rubber keys) is broken or the connection to the microprocessor is malfunctioning.
    Is anybody familiar with this?
    Kind regards,
    Bart
    P.s it is not a battery issue.
  • 09-09-2010 5:20 PM In reply to
    Re: Beo4 does not respond to keys
    The whole 'inside' is sold as 1 unit from B&O, so if it still looks good (housing and keypad) you could order the pcb with the keypad-foil.
    What type is it ?? the dvd version seems to be more of a troublemaker (with the things you describe) than the old av version.
  • 09-09-2010 6:58 PM In reply to
    • Churchyardd
    • Not Ranked
    • Posts 31
    Thanks,
    I have the DVD version. I will contact my B&O dealer about a new PCB.
    Regards, Bart
