Latest post 09-06-2010 5:48 AM by ipaul. 3 replies.
Page 1 of 1 (4 items)
  • 09-05-2010 5:37 AM
    • root
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Posts 163
    • Silver Member
    woofer from Avant TV
    I am looking for a single woofer from an avant television.
    thanks
    marcel
    Marcel
  • 09-05-2010 8:05 AM In reply to
    Re: woofer from Avant TV
    Where are you based ? (i'm in NL).
    I have some of these, i think it's better to change them as a pair as there seem to be different models around and the amp has to be adjusted accordingly (but at least with 2 the L and R will be the same).
    You're sure the woofer is broken ?, it is powered by it's own amp (avant has 2x 2 poweramps, 1 for every speaker).
  • 09-06-2010 3:33 AM In reply to
    • root
    • Posts 163
    • Silver Member
    one woofer is blown. it's definitely the woofer.
    how much do you want for the pair?
    Marcel
  • 09-06-2010 5:48 AM In reply to
    Oh, you could have them for free (i took them out of a 'dead' avant because it is a waste to throw away but have no use for them), if you'd pay for the P&P.
    If you mail me the exact number on the back maybe i have the exact same one ? (i recall it depends on the extra number on the unit how you have to re-adjust the equalizer of the amp).
