I was looking further in to a BV8-40 and in the manual it shows:
> 2 x HDMI
> 3 x SCART
> 1 x VGA
> Powerlink, Masterlink, (RF Out, DVB, and Aerial - all of which look coaxial cable connections)
> Smartcard
It got me thinking, is this the same specification the world over? Or does it vary from country to country?
Scart has zero relevance to me (it's ancient and it's such a huge size connector which you could fit more HDMI's instead or at least component) and
what is the smartcard used for? Could I potentially plug in my foxtel card and it would work without the foxtel box?
VGA has zero relevance to me as well, if i wanted to plug in a computer, I would rather DVI (i appreciate that you can get a HDMI converter) or if i was going to plug a computer into a TV, i probably wouldn't (most now have HDMI now anyway)
Does anyone know if it looks like B&O will update this television to have at least 3 HDMI's? For me that is the minimum number I would need. And is the panel 100Hz at the moment?
Thanks in advance,
Michael.
