I am servicing a Beocord 5000 tape player. I have downloaded the service manual and it is clear that this is a unit that is intended to be fixed not dumped when it stops functioning. Seems to be well laid out.
I recently bought the unit together with a full 5000 system. There are a few minor issues with the system. I am starting with the Beocord then will move to the Beogram CD50 which like the Beocord I suspect has mechanical rather than real electronic issues.
The Beocord worked once when I first got it home. All lights work and pushing the play etc buttons things happen. Likewise when controlled from the MCP. I think the issue is mechanical but I am new to servicing tape decks.
Symptoms are when you push play with a tape in the slack is taken up and then it automatically stops. This is like it came to an end of the tape. Similar occurs when you push FF etc.
With the covers off and the control panel lifted off I found that a belt is broken; just to be clear this is a belt that is associated with the tape drive mechanism (I mention this as I am unsure if there is another belt somewhere doing those bells and whistle things that make the system so date less - unless you know some history the system looks very hi-tech and stunning that most think it is a new manufacture
Questions:
- Can anyone tell me what belt I am after - specs etc?
- Is this belt a hard to get item?
- Are the symptoms above likely to be fixed by a new belt?
- Are there any things I should check whilst I have the covers off?
Thanks to all and in anticipation and also for such a good site and forum.
Cheers
Richard
