Hello All
Help needed.
My build is 7.14 with all modules up to date apart from the DSM module.
When i bought the tv the dealer did auto update and this did not update the DSM module, i mentioned about this as i need the module to have a higher level so i can use ML delay to fix the echo issue.
The dealer in question said as far as he is concened its up to date and flashing it again would give the same results.
Today i had another dealer try and update the software:
Read software ok all modules showing up to date apart from the DSm which is hardware version 2.5, (only boxes ticked are dsm to update)
We click select software to update and the start and get
communication issue message from the service tool.
Selecting the dsm module rather than auto update gives an error saying tv is not connected or powered off or needs a reboot.
This is strange as it reads ok but will not write to the DSM.
Help Please all you helpful experts.
									    Beovision 7 MKIV (Blu Ray)
Beolab 9
Beolab 6000
Beo 4
Beocenter 9300
Apple TV
SKY HD
Optoma HD65 Projector
Lintronic TT455-RT-238
Beovision 3 MKII
