Latest post 09-05-2010 5:10 PM by Carl Sheerman. 9 replies.
Page 1 of 1 (10 items)
  • 09-02-2010 2:24 PM
    Beocomm 6000
    I recently had to buy a new battery for my beocomm 6000 which didn't cost as i thought it would.  The phone which has a little LED light on the back just keeps blinking and blinking however the phone works fine.  I even tried changing the battery to a working one from another handset and still it blinks, but it still works.  Any help would be greatly appreciated.
    Carl Sheerman
  • 09-02-2010 3:11 PM In reply to
    Re: Beocomm 6000
    After installing a new battery in a 6000: 9#9#9*655
    • B&o bottle opener
  • 09-02-2010 3:23 PM In reply to
    Re: Beocomm 6000
    just tried putting that in and the blinking is still on.  Question do you just type it in and the flashing should stop?
    Carl Sheerman
  • 09-02-2010 3:47 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beocomm 6000
    Carl, sorry to state the obvious, but have you scrolled through all 24 Caller ID numbers?
    Press "Caller ID" twice, and make sure all of them say "No New Calls".
    Hope this helps.
    Andy T.
    Poor me, never win owt!
  • 09-02-2010 3:51 PM In reply to
    Re: Beocomm 6000
    Andy... the obvious is the best place to start! Carl... sorry... after entering the code -press the center button.
    • B&o bottle opener
  • 09-02-2010 5:05 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Beocomm 6000
    If none of the above help, you could just go into the set up menu and switch off the alert light Whistle
    Opman
  • 09-03-2010 3:51 PM In reply to
    Re: Beocomm 6000
    I have put the numbers in but to no avail the red light still flashes at me.  It just seemed to reset the battery but then nothing else.  As for the setup to turn the light off that worked but i am still wondering what the hell it is caused by.  Anyway its gone for now so please tell jandyt to stop stating the obvious LOL.  Thanks guys.
    Carl Sheerman
    Re: Beocomm 6000
    Carl Sheerman
  • 09-05-2010 5:01 PM In reply to
    • Opman
    • Cheshire, UK
    • Posts 323
    Re: Beocomm 6000
    We maybe missed a step with your flashing alert light before simply turning it off.
    When it flashes, you can press the button in the middle of the wheel and it gives the reason for the flashing light. Pssible causes are missed calls (check caller ID log), line busy - another handset is on an call or loss of signal to base.
    Opman
  • 09-05-2010 5:10 PM In reply to
    Re: Beocomm 6000
    Yup i have since checked all my other phones and they have the alert light turned of as well.  It was a feature i knew nothing about until now.  Anyway its gone for good now so thanks again.
    Carl
    Carl Sheerman
