Latest post 08-30-2010 9:20 PM by fdejong. 6 replies.
Page 1 of 1 (7 items)
  • 08-29-2010 1:04 AM
    Which double sided tape for my Beocenter 7700 tt cover?
    I've been busy restoring this fantastic Beocenter 7700 and one of the last things left to do is to reattach the plastic turntable cover.
    Looks like the old double sided foam tape disintegrated.  Can anyone recommend a product to replace it with?
    After cleaning, with the cover in place, but not attached.
  • 08-29-2010 2:39 AM In reply to
    Re: Which double sided tape for my Beocenter 7700 tt cover?
    Nice looking 7700 - including remote.  I've used double sided tape from an ebay seller and it is sticky stuff.  He sells a whole variety of sizes so you can get the size to match.  This is the tape I bought for fixing some 900K speaker grills.:
    http://cgi.ebay.co.uk/BLACK-DOUBLE-SIDED-FOAM-TAPE-6mm-x-10mtr-SUPER-STRONG-/180458546438?pt=UK_Crafts_Cardmaking_Scrapbooking_Glue_Tape_EH
    Dave
    Am I ready? I was born ready!
  • 08-29-2010 3:35 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Get that bsort of tape from motorparts shops its used for numberplate mounting(in UK)
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 08-29-2010 3:43 AM In reply to
    @fdejong
    Got some spare left, pm me!
    Leslie
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 08-29-2010 3:11 PM In reply to
    Thanks for the offer Leslie - but I"m far away in California!  I assume I just have to find some relatively thin double side tape - but not the thinnest kind?
  • 08-29-2010 5:55 PM In reply to
    fdejong:
    No probs, will send it for free if you give me your adressWink
    Other members did the same thing for me....
    BTW, your name sounds pretty Dutch to meSmile
  • 08-30-2010 9:20 PM In reply to
    Thanks for the generous offer Leslie - but I don't have enough patience!  I got some double sided tape on Sunday and got the cover back on today.  It worked!
    Yes, I was born in Holland but live in America now :)
