Latest post 08-28-2010 11:32 AM by tournedos. 3 replies.
Page 1 of 1 (4 items)
  • 08-28-2010 10:38 AM
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Beocord 5500: Return/Advance not working
    Hello all.
    Some years ago I aquired a Beocord 5500 which had trouble with the playback head, one channel was dead. Thrue Beoworld I was able to get the mechanics of another BC5500 from where I get the replacement head. The mechs. weren't of the exact same type but I was able to replace the head and get the adjustments so that it sounds good on both directions.
    Unfortunately I didn't take note how the three wires to the sensor on the left-hand side of the playback head connect. If I am not mistaken, this sensor senses the signal during winding and enables the use of Return/Advance, ie. moving automatically to the prev/next track. In the current way I have connected it the sensing doesn't work, ie. pressing Advance the tape keeps winding forward without stopping (tested with a tape recorded with BC9000 where the tracks are "marked" and work).
    Could someone post here a photo of the correct connection? Or if the signal-senes doesn't work this way what could be causing the problem?
    Bang & Olufsen - The art of controlling sound, picture and light
  • 08-28-2010 11:19 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocord 5500: Return/Advance not working
    I don't remember exactly but isn't that the end of tape sensor (optical) ?
    I think it senses signal gaps using the playback head.
  • 08-28-2010 11:27 AM In reply to
    • lausvi
    • Posts 498
    • Gold Member
    I noted the end-sensor in the service manual, and that would seem logical as there is voltage (red wire) for the (ir)-led.
    Could there be an adjustment for the signal gap sensitivity? And the new head having different characteristics?
  • 08-28-2010 11:32 AM In reply to
    I thought so too... My BC6500 is quite unsensitive - or should I say too sensitive - for the track gaps. If there's any noise like vinyl scratches in the recording, it runs right past them. There doesn't seem to be an adjustment for the sensitivity either.
    I have a 1982 JVC deck which counts the gaps much more eagerly.
    -mika
