Hello,
I want to add a subwoofer to my Beosystem 8000. I will be building the sub myself, using a plate amplifier I've had on hand for awhile. My slight predicament is that this amp has only line-level inputs, and the line-level outputs from the BM8000 are fixed level, of course.
I suppose I could use a line-level converter from the speaker level outputs of the BM, but I had a different idea that I thought might be a technically better solution.
I was thinking about breaking into the preamp outputs right before they go into the power amp boards, splitting off, and wiring those leads into the tape 2 output located at the flip-up connection terminals under the aluminum lid.
My question is; do you think the Beomaster's preamp will be able to drive this load? The input impedance of the subwoofer plate amp is 33k ohms.
Any help is appreciated. Thanks!
Jon
