1st March February 2012
Latest post 08-30-2010 6:19 AM by Medogsfat. 9 replies.
08-27-2010 2:13 PM
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
AV5... the tube... good or bad?
Hi guys,
long time since I've been here.
I'm thinking of getting an AV5 for the bedroom. These can be had pretty cheap now, but what about the tube? Is it prone to fail? Is it an expensive one to replace?
Andreas
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Dude1
- Joined on 09-18-2007
- London
- Posts 189
Re: AV5... the tube... good or bad?
Mine is good.... :)
To check a good Bang tube, the picture should be clear, bright and with vivid colours.
If they are dull, forget it...too much $$$
ernie
- Joined on 10-28-2007
- Posts 114
Tube problems are mainly found in the wide screen televisions. AV5 is a very good machine with an excellent picturequality and very reliable.
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Not sure which tube is used in the AV5, but I know the AV9000 used the same as an MX6000. Quite easy to pick up an MX for the tube.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
bayerische
- Helsinki, Finland
- Posts 3,593
But the AV5 is a 25" isn't it? Mx 28"...
-Andreas
ernie
- Posts 114
AV 5 was a solitary machine in the B&O tv range, 63 cm screen. You could argue that it was later replaced by the Beocenter 1.
ernie
- Posts 114
AV 5 has a smaller tube, 63cm which was never used in MX series....
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
I've been dealing in AV5's for about 10 years - and have never had a tube fail. I'm not saying they don't fail - i may have been lucky, but surely not that lucky!
Early curved 28" Avant tubes are the ones that are popping for fun - I'd say around twice to thre times the rate of 32" versions. Again, only in my experience, but i do get through quite a few!
Buying a 4:3 screened TV is a bit of a pain though, unless you're happy with your 25" screen emulating an 18" screen when showing a widescreen movie..
Lee
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
ernie:
I could be wrong but I'm sure one of our members (possibly Nobby?) successfully transplanted a tube from a LX5500 into a AV5.
Chris.
Page 1 of 1 (10 items)
