1st March February 2012
Latest post 09-01-2010 4:30 PM by 2121marty. 18 replies.
j0hnbarker
- Joined on 04-16-2007
- LS28/GB
- Posts 2,002
Re: Beosound 3000 connection to standard speakers, please dont hate me!!!
You'll need an external amp. Some people quite like Quad 405s for this. I think Nigel (H1NPW) has one of these in a similar setup, and I'm sure quite a few others do too.
2121marty
- Joined on 08-25-2010
- Posts 21
I have a 2 year old onkyo amp, was more confused about the B&O speaker inputs, is there an adapter?? bit of a novice if you couldnt guess
Peter
- Joined on 02-12-2007
- Posts 9,572
You need a power amplifier only. If the onkyo has an input so you can connect the BS3000 and bypass the pre-amplifier, you are OK. Otherwise you need to sort out something else. A MCL2P would be the obvious choice as this will simply connect via a powerlink cable.
Chrisreunion
- Joined on 07-01-2007
- Reunion Island
- Posts 677
I agree with Peter, the MCL2P is the most obvious solution, you keep the Powerlink connection, the BeoLink possibilities via MCL, the auto stand-by feature and enough power for most solutions.
Reunion Island is greeting you!
2121marty
- Posts 21
Guys, thanks for the advise, however you are forgetting I am a complete idiot! kinda need walking through it, numbers and codes just confuse??? Looks like the amp you are suggesting is around £200, is this right, thanks in advance
Peter
- Posts 9,572
Don't buy a new one - a second hand one is fine! I gave mine to another member a few years ago. The reason the Quad 405 is popular is that it has lots of power and has a DIN input!
Peter
- Posts 9,572
The cable you show will work fine - as it says, it will work with a normal integrated amplifier but you will need to use the volume control of the onkyo. The Quad 405 is the correct power amp - You need to as Nigel or Graham, but I think a five pin DIN will plug between the two to work.
2121marty
- Posts 21
Cheers peter you have been a great help, in your opinion is the quad a better option than the mcl2p ? looks like it has quite a bit more juice! Looks like you could probably anchor a ship with it!!!
j0hnbarker
- LS28/GB
- Posts 2,002
2121marty: Cheers peter you have been a great help, in your opinion is the quad a better option than the mcl2p ? looks like it has quite a bit more juice! Looks like you could probably anchor a ship with it!!!
I think the Quad would wipe the floor with the MCL2P!!!
2121marty
- Posts 21
Sounds good, will go for the quad then... see what the nice people at the Nationwide say...
does it connect to the 3000 with standard B&O wires or is it not that easy
Peter
- Posts 9,572
The MCL2P is a good amplifier with a very nicely designed circuit. It
will just work. If critical, I would say it lacks dynamics compared to
the best amplifiers but I use the same amplifier in an ML/MCL converter
to power my upstairs speakers and am perfectly happy with this. The
Beomaster 7000 I used to use was better though.
I cannot really advise about the Quad. In principle it should be great but I have not used one.
j0hnbarker
- LS28/GB
- Posts 2,002
Peter :
From what I remember Nigel and Graham have said good things about the Quad in the past. There's some kooky heritage there too.
joeyboygolf
- Ely, Cambridgeshire, UK
- Posts 3,252
Correct John. I have used a Quad405-2 with my Beocenter 9000 and it is a fantastic amplifier. At least 100wpc into just about any load.
The OP will need a speacial lead which steve@sounsheavenly.co.uk can make up at very fair cost.
2121marty
- Posts 21
Thanks everyone, going to try and get a 405-2 at a decent price, guess they are pretty indestructable, so ebay should be fine????
Graham thanks for the link...re cable
Now lets talk speakers... maybe Ive pushed my luck with non B&O questions...
2121marty
- Posts 21
Just a quick update, purchased cable for the time being, works a treat, even coming out a pair of mission speakers I hear more from a CD than I have ever heard before!!! Need some decent speakers now!!!!
Page 1 of 1 (19 items)
