Latest post 08-24-2010 12:10 AM by Stan. 8 replies.
Page 1 of 1 (9 items)
  • 08-22-2010 12:00 PM
    BeoSound 3 - short loud hiss sound between MP3 tracks
    Hello - I have just bought a new BeoSound 3. I am trying to playback MP3 songs from 2 different SD cards and I have the same problem with both of them:
    Between every other song I get a loud but short hiss before the song starts. Is this something you have experienced and what might be the solution?
    The MP3 songs are in 2 folders in the root of the card and encoding comply with the guidelines of the user manual.
    PS: Why can the BeoSound 3 not handle SD cards of larger sizes than 2GB? (I've tried an 8GB that didn't work with the BeoSound 3).
  • 08-22-2010 1:14 PM In reply to
    • arned
    • Top 500 Contributor
    • Joined on 04-24-2007
    • Denmark
    • Posts 97
    Re: BeoSound 3 - short loud hiss sound between MP3 tracks
    BeoSound 3 only supports SD cards up to 2 GB in size from SanDisk. BeoSound 4 (mk. II) supports SD cards up 16 GB.
    I have the Beosound 4 (mk. II) using different SanDisk SD cards at 2 GB / 4 GB / 8 GB without any hiss. I am using my PC and Windows Media Player with 192 Kbps for "recording" the tracks.
    Try to format the card and then save some new songs into a folder from your PC.
  • 08-22-2010 1:23 PM In reply to
    I've tried formatting several times and added different songs and it still doesn't work. The SD card I use is from SanDisk and is 2GB a higher speed version of 15 MB/s called "Ultra II" but don't see why a faster card should cause any issues?
    I have also tried with a non-SanDisk SD card of conventional speed and 512MB but not of the brand SanDisk and I get the same hiss sound.
    I can convert new MP3 songs but if the product is soo sensitive to formats etc (and the songs I have added to the SD cards comply with the specifications) it is an odd product. I might have a faulty unit - what a shame.
  • 08-22-2010 4:28 PM In reply to
    • arned
    • Denmark
    • Posts 97
    Well - You might have a faulty unit - I dont think this hiss is normal on Beosound 3. On Beosound 4 i dont have any noise of any kind when playing SD card.
    It must be other members who has Beosound 3 and can help you! Or try the Bang & Olufsen homepage:
    http://www.bang-olufsen.com/beosound3
    and go to FAQ. There is something about SD cards.
  • 08-22-2010 4:51 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Sorry for being obvious, but do these MP3's sound OK on other kit than your BS3?
  • 08-22-2010 4:57 PM In reply to
    Hi, yes they are fine on other units. I've simply dragged-and-dropped them from iTunes to the SD card (Mac).
    Have sent an email to B&O customer service - let's se if they can cast some light on this. Will post here if useful info from them.
    Thanks for your input.
  • 08-22-2010 5:03 PM In reply to
    • Puncher
    • Posts 9,588
    BeoMedia:
    Are these downloaded MP3's or something you have encodec yourself - if so, what did you use to encode them?
  • 08-23-2010 3:25 PM In reply to
    Hi, I encode them myself from CD's using iTunes (I have a Mac computer if that makes a difference). I have just ordered a conventional slow speed 2GB SD card of the brand SanDisk which I understand B&O recommends so will se if it makes a difference.
  • 08-24-2010 12:10 AM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    I have 2 BS3's and I don't recall either making a hiss noise like you describe. Sad  I've used many different sized cards and speeds over the years.  I would guess it needs a repair, or (if repair costs are similar to other B&O costs) learn to deal with it Smile
    Stan
