Latest post 08-20-2010 4:57 AM by 9 LEE. 18 replies.
Page 1 of 1 (19 items)
  • 08-19-2010 4:37 PM
    • Beolab1
    • Top 500 Contributor
    • Joined on 08-04-2007
    • Hong Kong
    • Posts 232
    • Gold Member
    Forum problems?
    Is it just me in The Netherlands (it could be since we are the people who live below sea level), or is the forum having difficulties? The last few days it was slower and sometimes not available. During most hours last night it was impossible to enter.
  • 08-19-2010 4:56 PM In reply to
    • Odd88
    • Joined on 07-25-2010
    • Norway
    • Posts 86
    • Gold Member
    Re: Forum problems?
    same problem here tooConfused
    Blame google translate for my bad EnglishStick out tongue
    My Bang & Olufsen.
    • Beovision 8-40
    • Beosound 9000
    • Beolab: 5/3/2/8000
    • Beo 5 / Beo 4 / Beotime
    • Form 2 / A8 Earphones
  • 08-19-2010 5:00 PM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Re: Forum problems?
    Are you in a Fjörd?
  • 08-19-2010 5:06 PM In reply to
    • Odd88
    • Norway
    • Posts 86
    • Gold Member
    Re: Forum problems?
    no, about 250 meters above sea level...
    My Bang & Olufsen.
    • Beovision 8-40
    • Beosound 9000
  • 08-19-2010 5:53 PM In reply to
    Re: Forum problems?
    I have had same problem in the USA.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 08-19-2010 6:06 PM In reply to
    Re: Forum problems?
    Then it's the fact that you, Odd88, are to high above sealevel and we, Beolab1 and me, are to low under sealevel. I experience the same things.
  • 08-19-2010 6:27 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Forum problems?
    Hi all,
    Our server/hosting company for the forum appear to be having some torrid times.  Rest assured Keith is working on it - and if all goes to plan we'll have an absolutely first class forum with no connection issues and extremely fast response and refresh times, on our own dedicated server.
    Nothing is set in stone though - we have some bridges to cross and hurdles to clear first.  Lots of technical stuff which baffles me though..
    Lee
  • 08-19-2010 6:59 PM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Re: Forum problems?
    Is your server/hosting company either in a Norwegian Fjörd or below sea level?
  • 08-19-2010 7:14 PM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Re: Forum problems?
    Lennaert:
    Okay your theory is not bad, but how do you explain the American member above your post who has the same problems? He can not be in a Norwegian Fjörd or below sea level. He lives in Illinois, which is above sea level.
  • 08-19-2010 7:37 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: Forum problems?
    Huh?
    I used to have an ingrowing toe-nail.
    Please explain this...
     Weekly top artists:
  • 08-19-2010 8:02 PM In reply to
    • Beolab1
    • Hong Kong
    • Posts 232
    • Gold Member
    Re: Forum problems?
    It is caused by bad hygiene, neglect or incorrect toe nail clipping.
  • 08-19-2010 11:35 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: Forum problems?
    Beolab1:
    Fjord, Chevy, we all had the same problem.
  • 08-20-2010 2:12 AM In reply to
    • moxxey
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: Forum problems?
    9 LEE:
    Please tell me it wasn't on a VPS?
  • 08-20-2010 2:31 AM In reply to
    Re: Forum problems?
    9 LEE:
    Hi all,
    Lee
    Turn the record over, I've heard this several times before.
    Unless more members pay, the forum will always be running just to catch up. A dedicated server will soon be out of date and will need to be bigger and better just to keep up with the demands of the membership, most of whom, will pay nothing to use it.
    Regards Graham
  • 08-20-2010 2:34 AM In reply to
    Re: Forum problems?
    I can confirm that there was a problem on Wednesday evening until the following morning caused by an "Application Pool" timeout which happened because another process was holding onto a resource.
    It turns out that the holding resource was trying to read a picture file (jpg) which was corrupt and until that error was cleared it could not continue.
    The picture file in question was uploaded as an attachment to a posting and I am not going to say which picture file it was, only to say that the corruption was corrected.
    The above problem was totally unrelated to an on-going issue which some members may have noted which occurs particular at times of heavy Internet network traffic and/or heavy server traffic where when you either write a post or press the "Home" button you wait sometime and then get my "catch all" error message. If posting, it sometimes does do the posting, but does not quite finish before the timeout period. Unfortunately the timeout period cannot be changed.
    You may recall back at the begining of the year I moved the Beoworld web site to our own server under our direct control and I plan to do the same with the forum as soon as we can. There are a few technical issues to resolve first, the biggest issue is the fact that currently the forum runs on a server in the East coast of the US and of course uses US date format. As the date is used as part of the forum login process, if I was to move it to a European server no one would be able to login. So one of the big tasks is to create an SQL script which converts all the dates for every user on the system which is more than 13,000 changes. So, this move is several months away.
    However, in the meantime I have changed quite a few settings and certain code changes to improve or mask the current problem, in other words the core problem remains, but you may not see it or only rarely hopefully.
    One major change I will be making in the next few weeks to hopefully dramatically improve the forum relates to the search facility which uses a lot of SQL database resourses not only for actual searchs, but as part of the posting process. I will be installing an "Enterprise Search" to replace our current not very good "Search Barrel". This is a complex installation which I intend doing "on the fly" meaning the forum may pause for a few seconds, but will not go down during the upgrade. The exact time and date has not been decided yet.
    I will keep you all informed on progress, but the major changes will not occur until after I return from my holiday in Italy meaning after 14th September.
    Regards Keith....
  • 08-20-2010 3:58 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Forum problems?
    hasta la pasta for the jollies in italy keith
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 08-20-2010 4:17 AM In reply to
    Re: Forum problems?
    Beolab1:
    Lennaert:
    He's just to far away, the entire ocean stands between us and him! Americans should stick with their own stuff. Keep your hands off our B&O! No just kiddin...
  • 08-20-2010 4:29 AM In reply to
    Re: Forum problems?
    Can I just say that I remember the days of the 'old' Beoworld where the forum used to crash several times a day, and the recent issues pale into insignificance compared with what we had to work with a few years ago :)
  • 08-20-2010 4:57 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Re: Forum problems?
    joeyboygolf:
    You did, and we ended up on our own server for the main forum!  This costs a fortune but it's totally stable - just like the forum will be if we can move it to our own server.
    Yes - financially it's a struggle, but we'll get there! Smile
    Lee
