Latest post 08-20-2010 4:10 AM by lausvi. 1 replies.
Page 1 of 1 (2 items)
  • 08-19-2010 1:45 PM
    Bm1000 to experiment on.
    I have just got hold of another BM1000 which I plan to do some work on to hone my soldering skills. Its an early white key version that has Danish towns/stations on the dial instead of the normal frequencies. One channel is rather crackley so I am hoping to be able to sort this out by changing caps, any hints as to which it may be or should I just change the lot. . The whole thing is filthy inside, whats the best way to clean it up.
    I must admit that I only really got it to be a spares unit but its too nice to take apart and apart from the dodgy channel, its really nice.
  • 08-20-2010 4:10 AM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Re: Bm1000 to experiment on.
    I once had a Beomaster 1000 that had candle wax inside! Someone had had a candle on the top of the BM and the wax had poured in thrue the air vent holes on the top. Nothing was broken and I just removed the stuff from the circuit boards.
    Crackley channel could be caused by a dirty potentiometer (volume, other adjusts) or the push-buttons. Could be as easy as just applying some contact cleaner to the switches and pots.
    Bang & Olufsen - The art of controlling sound, picture and light
