Thanks Martin
Wouldn't know the differences the original platter had a peripheral skirt , the 2200 platter is basically an unskirted disc, which with the height of the assembly reduced does not look too bad the clearance is about 2mm - and works well its just to get the whole back to original - not to worry I'll carry on as present
salut
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
