How to connect BL8000 + BL6000 + BL4000 + BL2 + BC2 to Pioneer TV?
BS1/BS2/BS3
third-party amp with pre-outs
Like this one - you'll only be using the pre-outs, but you can set levels from the receiver, and you'll get an excellent 7.1 sound, while you can connect whatever sources you have through the INs.
http://www.cambridgeaudio.com/summary.php?PID=493&Title=Azur%20650R%207.1%20AVR%20with%20HDMI%201.3c%20reception%20and%20processing
soundproof:Like this one - you'll only be using the pre-outs, but you can set levels from the receiver, and you'll get an excellent 7.1 sound, while you can connect whatever sources you have through the INs. http://www.cambridgeaudio.com/summary.php?PID=493&Title=Azur%20650R%207.1%20AVR%20with%20HDMI%201.3c%20reception%20and%20processing
-Dimitris
using phono/rca sockets and the line-in inputs
KingOfSnake: third-party amp with pre-outs
The speakers should work, but will the BL2?
And presumably the speakers will need to be manually turned on, unlike a Beosystem solution?
Justin
