Latest post 11-28-2010 3:54 AM by jolabari. 8 replies.
Page 1 of 1 (9 items)
  • 08-17-2010 11:13 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Link Room Audio
    Hello All
    I have an Apple TV connected to my BV7 with the latest software.
    I read in the software thread that after the new version we would be able to access audio from HDMI sources without having to connect the AV leads and SKY for example with the Scart lead.
    Did this ever happen as when i am in a link room and press Vmem i get sound only if i have the AV leads connected aswell
    This gives me an echo which i will fix when my DST module is updated as its the only part of the last build that was not updated for some reason.
    Am i correct in thinking that i should now be able to have the devices connected with just HDMI and access there sound in link rooms?
    Maybe Link Vmem or something?
    this page talks alot about it http://forum.beoworld.org/forums/t/31193.aspx?PageIndex=3
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 08-17-2010 4:11 PM In reply to
    Re: Link Room Audio
    Hi Seanie
    What happens if you press AV Vmem?
    That should do the trick, at least it does for my mini connected with DVI and S/P diff
    /Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 09-13-2010 4:36 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Link Room Audio
    Hello All
    Just an update to this thread.
    Since having my DSM module updated i can now listen to sound in my link room for HDMI devices that are connected by HDMI only.
    The sound has no delay as i assume its using the sound from HDMI and converting back to analogue and down the ML cable.
    This is excellent news and means no longer do i need loads of extra cables connected.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 09-15-2010 10:49 AM In reply to
    • SVB
    • Not Ranked
    • Joined on 12-12-2009
    • Posts 9
    Re: Link Room Audio
    Does this post indicate B&O have solved their HDMI link delay issue?  We have a BV10 and listening to any HDMI source over the link gives a delay which our Dealer (Bath) have pretty much said is a 'feature' of the system and nothing can be done.
    Very unimpressed as the B&O CRT set-up it replaced as perfect!
    S
    BV10 - BL9 - BL6000 - BL2 - BS9000 - BL4000 - BL3500 - BL2000 - PC2 - BL4000 - B-Passive x 3 - BV1 - BS3000 - BL4
  • 09-15-2010 10:55 AM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Link Room Audio
    It has indeed for me fixed the delay issue over ML.
    Make sure you have the latest software for DSM module and a hardware DSM version above 1.5 i believe without the document in front of me.
    ( i will clarify in an hour when i get home)
    In the customer service menu there is an option called ML delay and that fixes the problem and i no longer need anologue cables connected for sound, i can also get sound from SKY HD which i coudl not before as it was only connected via HDMI.
    I believe the sound in link rooms is now the digital sound sent over the ML rather than the Anologue sound over ML.
    p.s
    Please be aware my experiance is only via link room audio and not video, but i believe that was fixed also by using AV command.
    If you need a copy of the requirements for the ML delay option to appear let me know.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 09-15-2010 12:04 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: Link Room Audio
    mmm the document i have says its valid for:
    BV9
    BS3
    BV7
    it says software build needs to be above 632
    DSM module hardware version 2.0 or 2.5
    and you have the option to select dsm in the sound menu.
    Nothing listed about BV10.
    These documents are avail to dealers so i reccomend you tell your dealer rather than fobbnig you off you tell him to investigate it further.
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 11-27-2010 12:03 PM In reply to
    Re: Link Room Audio
    Hello,
    I have recently connected Apple TV to my BV8-40 and my dealer told me i cant get neither Video nor Audio in the link rooms as the new Apple TV is digital and no way of converting to analogue. Can any of you learned friends confirm if this is the case before i investigate further? The TV has had a software update recently with the B&O logo showing instead ofthe ugly clcok..
     I have 2 other Link rooms and i can get SKY, DVD etc audi and video but i guess because of the scart connection to AV behind the sky box.
    thanks
    J
  • 11-27-2010 5:17 PM In reply to
    Re: Link Room Audio
    jolabari:
    Hello,
    thanks
    J
    Hello jolabari,
    I think this should work:
    http://www.normwandler.de/Downloads/Brochure/CM-388.pdf
    So you can connect the new Apple TV to your BV8-40 not only by HDMI, but also analogue. So you can use audio and video from ATV also in link rooms.
    Regards
    Räuber
  • 11-28-2010 3:54 AM In reply to
    Re: Link Room Audio
    Thanks for your response Rauber, guess im not looking to add another device as i had to install an Atlona switcher to provide extra HDMI ports to the BV8-40:-)
    Does anyone know of any other workaround that can be used to get Apple TV to Audio/Video  signals to link rooms?
    thanks
