Grand master? I've been called a lot of things... but that may be the least fitting, ever!
Sorry for the delay, my offline life was the definition of chaos the last few days.
OK...
Everything is accomplished from the BACK of the BC.
1.) (2) small phillips-head screws just below the TT plane. This will remove a small black trim piece that spans the BC. It will allow the rearward removal of the dust cover/hinge mechanism. Be careful that the cover doesn't spring and possibly crack the hinges.
2.) (2) medium phillips-head screws on either of side of the cage. This will remove the cage.
3.) (1) Captive grey DIN lead from TT to socket Q1 -pull.
4.) Carefully rotate the BC upwards so that you can locate (2) medium flat-head screws. This will release the complete TT assembly. Carefully rotate the rear of the TT assembly up and pull backwards. Rotate the entire assembly ~90D and release a lead that heads back into the BC (caveat: my BC clearly has been "serviced" and it appears there were changes to the wiring at this point -yours may differ slightly). The entire TT assembly is now able to be benched and serviced. I will recuse to others for motor service/lube. There are also quite a few threads on here regarding this. If I am not mistaken this TT is very similar, if not identical, to the 3000.
Notes: This is actually a pretty slick piece w/ the way that the TT assembly is one complete extractable unit.
Hope that helps!
