Latest post 01-06-2011 4:49 AM by EOB. 1 replies.
Page 1 of 1 (2 items)
  • 08-16-2010 1:16 PM
    • EOB
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 188
    BC 1 Upscaling motion picture view to1..33
    Someone has a BC 1 from 2001 that doesnt size up the screen, when a dvd is played. Meaning when you play a dvd and then push the blue button on the beo4. A selection bar on the upper screen appears. when I turn it into 1.33 view mode it scales up but freezes the motion.   When pressing "go "it scales down again.
    I have a BC 1 from 2004 myself which does the upscaling with motion picture just fine.
    Does anyone have an idea why the BC 1 isnt capable of scaling up in motion modus ?
    Is there maybe an SW update possible ?
    The BC 1 - 2001 came originaly with a beo1
    The BC 1 - 2004 came originaly with a beo4
  • 01-06-2011 4:49 AM In reply to
    • EOB
    • Posts 188
    Re: BC 1 Upscaling motion picture view to1..33
    Ok, asked a the dealer and he said the BC1 from 2001 isnt capable and there is no way to update it so it will be capable.
    Maybe a tip  for people who want to buy a second hand BC1.
    Another tip is to ask if the DVD is already been replaced because it seems that even the 2004 series have a known failing problem with that specific feature.
