Hello all
When I connect my MP3 player to the aux input of my 9000 I have to turn both it and the 9000 up to full volume (72 !!) to hear any sound at all. Is there anything I can do to fix this?
Chris
I suspect you have a DIN - 3,5mm plug adapter that is wired for the wrong direction (i.e from the DIN to the plug). Therefore you are not getting the actual signal, just some crosstalk.
-mika
Agree. Just get a DIN to 4x cinch adapter, so you have inputs and outputs. Now you can find the AUX ins....
Stefan
Thanks, I'm using two cables, a 3.5 to RCA then RCA to DIN. I'll check its connected OK or replace the two cables with one I know is OK.
Sorry for late reply.
I changed the cable for a known good one and it works just fine. thanks for the pointers. chris
