Well - i've brought a BeoMaster 5 home to use..
I absolutely LOVE the Net Radio, but the problem is my music.
The previous owner kindly loaded a fair bit of music onto it, which isn't all that bad. However, i have all of my music on my Mac - which has come via iTunes, iTunes Plus and directly loaded and copied CD's. Some are DRM protected, some aren't.
I've done the BeoConnect, which went perfectly - then highlighted and dragged a batch of random songs from my iTunes and dropped them into the area marked 'MUSIC' on the BeoMaster display. They transferred without a hitch.
However, little padlocks are on the mpeg 'labels' - and these songs don't even show up when you try and search for them.
As i understand it, these are DRM protected. So - first question is.. how do i launch a rocket into my iTunes and wipe off all the DRM. Is it easy?
Secondly - the songs/albums already on there are in wonderfully neat little 'windows style' folders, with the artist name at the bottom. Very twee. However, when i dragged and dropped from iTunes it just listed them as individual songs. Will this make a difference in any way to playback and search?
And.. finally.. (deep breath).. i see that the songs already on there are all in WMA, not mpeg like the ones i dragged and dropped. Is WMA better? What's the best format, and how can i fire rocket number two into my iTunes library and convert them all to the best format to drag and dump into the BeoMaster 5 ?
I'll forgive anyone who's glazed over - or has already given up as the reply would be too long..
Lee
