Latest post 08-15-2010 10:26 PM by mediabobny. 3 replies.
Page 1 of 1 (4 items)
  • 08-15-2010 4:51 PM
    BeoSound 2000 Century active antenna activation
    I have a BeoSound 2000 (US), and am going back to using the active antenna with integrated handle.  I remember something about setting something to activate (power up) the antenna circuitry, but I can't remember the details nor find the instructions for this.  This seems confirmed by its inability to pick up many stations.
    Do any of you remember what the trick is to activating the antenna, or is there no such thing after all?
    -- Paul
    Filed under:
  • 08-15-2010 5:28 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: BeoSound 2000 Century active antenna activation
    No such thing as as far as I know - it's not an active antenna.  Unplug it and use a dipole antenna that you can purchase on eBay instead.  You'll get much better reception.
  • 08-15-2010 10:03 PM In reply to
    The FM antenna is active, at least according to the User Guide and also in the BeoWorld writeup: http://www.beoworld.org/prod_details.asp?pid=950.
    -- Paul
  • 08-15-2010 10:26 PM In reply to
    • mediabobny
    • Posts 336
    I sit corrected - apprently it is.  To make sure the BS is set up for active antenna mode,  Press . (standby), then TUNE, 1, STORE.  The digit  1 will be briefly displayed.
    I always used a dipole antenna iwth mine and got good results.
