1st March February 2012
08-15-2010 2:56 PM
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
Simple question on Beomaster 8000
Hello, yesterday I bought a fully functional Beomaster 8000. The only problem is a distortion problem in the left channel... Can it be defective electrolytic capacitors in the left channel?
-Søren
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
Dillen
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
Re: Simple question on Beomaster 8000
It could be a capacitor problem but it could also be something else. Is it drastically distorted or "only just" ? Is the "Clipping" light flashing ? Have you tried swapping speakers to rule out that the fault lies in one of them ?
Søren Hammer
- Esbjerg/Denmark
- Posts 554
In my opinion is the sound very distorted, especially in the high frequencies, no "clipping" light flashing, it doesn't matter if the filters are on or off. I have tried the Beomaster with different speakers, and the problem is reoccuring in the left channel.
-Søren
Dillen
- Posts 5,008
Most likely a small signal transistor somewhere, maybe in the amplifier stage, maybe earlier. You will have to put a signal generator to the tape input (if it also distorts from tape) and a scope to the signal path and see where the signal gets distorted.
Premiumverum
- Joined on 02-02-2009
- Netherlands
- Posts 208
Could be a bad solder joint I think. Very common in BM8000 and they gave me some weird problems with faint, distorted and failing channels.
Good luck!
henrik
- Joined on 04-16-2007
- Stockholm, Sweden
- Posts 299
Another point of failure is the speaker switches. Ok, that's probably not your problem in this case, but it's still worth mentioning in bm8000 threads as I have had that problem on all of my three 8000s.
Søren Hammer
- Esbjerg/Denmark
- Posts 554
Sounds like a minor problem that easily can be fixed. The Beomaster was bought by a person who refurbishes all his B&O himself. I have managed to let him have a look at the Beomaster.
-Søren
Page 1 of 1 (7 items)
