Latest post 08-15-2010 7:22 AM by Dillen. 2 replies.
Page 1 of 1 (3 items)
  • 08-15-2010 5:47 AM
    Slider Tuner Plate needed for - BEO Master 1200 Tuner
    Hi Folks,
    I have inherited a BEO Master 1200 Tuner. I am now restoring it to it's original condition.
    I am in need of the sliding tuner plate !!!
    Any help in locating the slider plate hugely appreciated.
    Regards, Paul.
  • 08-15-2010 7:15 AM In reply to
    Re: Slider Tuner Plate needed for - BEO Master 1200 Tuner
    bandomaster:
    Hi Folks,
    Regards, Paul.
    See response to your wall mount query.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 08-15-2010 7:22 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Often missing and very hard to find unless from a donor Beomaster.
    The slider is actually 10 separate parts:
    Two Nylon pins at the rear
    Rear bracket
    Window
    Front bracket
    Two springy nylon sliders
    Three fingerwheels
    Sometimes the nylon pins and springs can be found in their respective
    grooves in the aluminum dial plate.
