OK...
BIG update...
I think this may end up being a rather short-lived thread! I hope I didn't just jinx myself.
As the OP posted... The lights are on but nobody is home. His description pretty much summed the BG up upon its arrival to me. In dealing with John, it was my understanding that the unit would be a bit of a crapshoot and may just end up being a parts unit. As the TT arrived in partial state of assembly, I first put it all back
together to gage it in its entirety. I then broke it back down for evaluation.
Cosmetically: I think that the unit is not too bad. A little "patina" adds to the history of some of these older pieces. I think that some folks can drive themselves crazy striving for that last little measure of making something look like it just came out of the factory. I will add some pics when I have a chance... but all-in-all... The trim looks good, the wood needs to be dealt with, and the dust cover is just beautiful. John must have spent hours polishing it up and it really looks fantastic!
A general clean up, some sorting through my parts bin and we should have a winner. One interesting point... when the beancounters got involved and the 4002/4 was born... they actually changed the dust cover strip from an aluminized tape to an actual strip of aluminum -seems odd! At any rate, the original tape strip is too far gone. John supplied a really nice looking strip of brushed stainless (not aluminum) that I will use.
Electronically: Hmmm... First thing I noticed is that the mains lead had been changed at some point with some ugly acorn style terminals -yuck. I will likely replace w/ an original soldered in properly. DIN plug is still there though (no typical USA RCA conversion)! There is some corrosion present in the socket -so I may go ahead and replace it at the same time as the mains lead.
Without anything in place, tapping the ON switch brings light to the control panel and arms. Switching between 33 and 45 lights the appropriate fine adjust screw. Depressing the traverse and U/D switches does nothing. Motor (OM2???) just sits there. Well, I should be able to move the transport back and forth by rotating the drive screw. I start spinning the pulley with my finger and off she goes! And stops! Spin it back -off she goes and stops! This is clearly some sort of physical stop -something lodged in the mechanism? Hmmm... I'll sleep on it.
Last night... Welcome to Mezzavino Engineering. That would be: Half a bottle of red and let's mess with the BG! OK... where were we? Oh yeah -transport won't budge. Wife isn't home, so I plop the stripped BG onto the stove top and slowly start the screw in/out process -repeating for about 5 minutes, when... what is that?!?! Hmmm... a small cad-plated looking screw with a flat washer wobbling back and forth in its socket every time the transport moves. It is located just south of the solenoid and just doesn't look right. It looks like it is acting as a transport screw!!! The 4002/4 doesn't have one... the 4000 owner's and service manuals don't show it, and of course, the setup manual -which I don't have ...might! (anyone?)
OK... gulp of vino... that screw is coming out! Back to spinning the drive screw in... THAT WAS IT! The transport went right on her merry way. Back and forth a few times... we are good to try a record.
Place the platter, belt, cartridge, etc... Now remember, the transport motor is out -so I had to manually drive the transport. I depress the ON switch, everything lights up. I spin the drive screw again... Needle gets to the edge of the record -and drops! I lower my ear to the cartridge and I can hear the music. I try U/D switches -beautiful! I tap the OFF switch and reverse the spin of the screw and drive the transport back home. As it depresses the limit switch -presto, off it goes!
So, where am I? I have what seems to be a functioning TT w/ the transport motor in question for now. From the flow chart (cursory look) what voltage should I see there? If it is the motor, will a 4002/4 motor work? Also, this still needs a thorough cleaning and lube still as well as maybe reheating solders, and I haven't even amped it yet to see what I am getting out of it... more to come!
