Dear All,
Today I was purchased a pair of Beolab 4500, which are working fine - except they do not turn on with a Beocenter 2300 or with a Beocenter 2500 (both two way versions), and the displays are not working :(
The following cases was tested:
With a simple 5 pin cable both speakers were turned on, and worked well, except the display.
With the power link cables the Beocenter+Beolab combination is working fine.
With an AV9000 the BL4500 displays working fine
BUT
When I put the powerlink cables into the Beocenters and into the BL4500... then nothing happens, and I'm clueless now...
Does it really means, that these, almost the same time B&O systems can not work together in peace and harmony? :(
If the answer is yes, than can You please help me out, which Beocenters or Beosystems are fully compatible with the Beolab 4500?
Thank You in advance! :)
AT
