Recently I found a Beocenter 3500 on the attic of my gran. Luckely it still works, but i'm concerned about the TT (the main reason why I wanted it :) ). The TT-belt has been off for a while (for some reason it was jammed underneath the center rotor (on which the record turns)). When i try to put it on, it slips down by itself when i turn the rotor (maybe it's has slackend??), it doesn't fall down when i don't move the rotor. Although I haven't tried it with a record on it, it won't turn automaticaly when I push the lift button (or so I guess). When I turn it by hand everything works: the arm moves in, lowers and at the end of the record it returns to it's original position.
Can anybody help me? How can I make it work?
Greetings
